GMCOPO Speedo Stuff
+2
Bluemach1
6 posters
GMCOPO Speedo Stuff
GM CMCOPO. Never heard of them. Can any of this stuff be used for our speedo issues?
Re: GMCOPO Speedo Stuff
What Speedometer problems are you having? I never had to do anything for the speedo. The Tachometer yes, but the speedo should work the same as it did with the 4 cylinder.
Oh okay. I checked out the link and its for the VSS. I guess you could adapt it to the 944 transmission speedo gear but the speedo gear in the 944 transmission is spinning pretty fast as compared to the wheel speed. So im not sure if it would be worth the money and time to adapt it. Plus, you would have to either lose your speedo or "T" off it somehow so that both VSS and your speedometer works. Either way, you have to program the computer, buy this device, adapters, custom....etc.
Best so far for the VSS issue is a gear from mcmaster carr or a stock 944 cam gear modified and bolted to the CV with a GM VSS sensor. Low cost and easy.
Do I need to put together a "VSS Kit"?
Real easy...
Whatcha thank?
Cheapest sensor I have found is around 70-80 bucks, plus you will need a fabbed mounting bracket, and a modified 944 cam gear. Prices are running up...
The $125 GMCOPO sensor is the sensor only. No wheel, no bracket, no adapter...nada.
Real easy...
Whatcha thank?
gt1scca- Posts : 795
Make a Kit!
I've purchased the GM VSS sensor for $29 bucks or so at Advanced Auto, I haven't adapted it to my car yet, a previous post I made stated that I will attempt to mount it at the rear ABS location in the trailing arm. This is my going forward position, but if a kit was available, I may be swayed from that.
Found it...87-944S wrote:I've purchased the GM VSS sensor for $29 bucks or so at Advanced Auto...
(Even comes with a bracket!)
Kit's a-comin'...
Here's the modified reluctor wheel.
Make it yourself, use a trimmed 944 cam gear, or buy the VSS Kit here...
944v8s.com
944v8s.com
I could be wrong, but i don't think that bracket holds the VSS snugly. It is meant to hold the VSS *in* a hole.
I think if you made the reluctor wheel and supplied a piece of angle-iron, people could probably take it from there...
I bought one today for some R&D. The existing bracket will not be used with the "Kit".Porch wrote:I could be wrong, but i don't think that bracket holds the VSS snugly. It is meant to hold the VSS *in* a hole....
I may have been a little optimistic at first glance, but now a proper bracket can be designed.
[So, you caught that too, Eric?]
