Errors/changes/omissions to the "Manual"
There has been some recent chat about the "Manual", we know that it's not perfect and that certain errors or omissions exist.
I would like to suggest that you start a new Board Topic where we can post notes concerning errors and ommissions that we identify during our swap activities.
There should be some rules, no flaming, no discussions just simple posts that identify page number and the item or data in question. No "My way is better than yours" discussions, simple facts.
I have three items to post immediately.
Last edited by fliermike45 on Sun Mar 06, 2011 5:59 pm; edited 1 time in total (Reason for editing : Change topic title)
Re: Errors/changes/omissions to the "Manual"
I have a bunch too.
Honestly, it would be better off creating a new manual or new information. This "edit on page 5" style won't help anyone who could not get a hold of the manual themselves.
robstah- Posts : 352
The Manual
Agree with you about not having a manual but the point is to at least get something written down at a central point with easy access.
Here's the place to put all that information...................................
LSX Bell housing
The LSX Automatic transmission bellhousing will NOT work with the stock clutch assembly.
Last edited by fliermike45 on Sun Mar 06, 2011 6:09 pm; edited 1 time in total (Reason for editing : Added LSX)
LSX Water temp sender
The LSX water temp sender specified in the manual requires an adaptor from 3/8" pipe thread to 12mm
Last edited by fliermike45 on Sun Mar 06, 2011 6:08 pm; edited 1 time in total (Reason for editing : Added LSX)
LSX Oil pressure sender
The LSX Oil pressure sender specified in the manual requires a 1/8" pipe to 16mm adaptor.
LSX Engine Mounts/SetBack Plates
The LSX passenger side engine mount/set back plate indicated in the manual will not work with a F Body AC Compressor.
LSX Oil Pan
If you use the "Moroso" oil pan for the LSX, you need to obtain a modified Moroso oil pick up tube.
This is indicated in the manual. (I missed this fact until I rechecked the parts list.)
Last edited by fliermike45 on Mon Mar 07, 2011 7:28 am; edited 1 time in total (Reason for editing : Corrcted eroneous statement.)
Transmission plate in the manual will not fit over the gears as it's drawn.
Set back plate drawing have hole locations wrong on them.
Oil pressure sending unit in the manual will not read accurately with a factory turbo gauge sometimes...
What is the preferred model number for the oil pressure sender?
Admin wrote:I've started using the factory sender.
It would be nice if someone sold an adapter to fit the factory one back in where the LSx one is. I know it would be small enough. My only issue was that the factory one off of my old motor was busted up pretty bad and I needed a new one and was not going to pay Porsche prices.
"manual" thread
Hey guys there is a separate thread to discuss the Oil pressure sender.
I would hope we keep this thread to identify the errors/omissions in the "manual"
LSX Thermostat housing.
The CSR Thermostat Housing specified in the manual requires modification or an adapter plate to work with the LSX thermostat.
» Gregg Sloan
» V8 conversion manual
» Gregg Sloan
Today at 5:26 pm by Raindoc
Yesterday at 4:06 pm by Rob44
Wed May 01, 2024 9:32 am by Rob44
Tue Apr 30, 2024 9:28 am by JW1970
Mon Apr 29, 2024 11:36 pm by zenon
Mon Apr 29, 2024 11:24 pm by zenon
Sun Apr 28, 2024 10:38 am by SpeedRacer11
Sun Apr 28, 2024 1:00 am by Raymond-P
Sun Apr 28, 2024 12:09 am by Raymond-P
Fri Apr 26, 2024 4:30 pm by ThomasJoseph315
