Check your RH Engine Mount Uprights
Had a clunk in the front end on braking. Found this:
Sorry, can't get the picture to post.
Had it rewelded and ground down. This winter I'm going to have the uprights remade with much thicker bases.
marc a- Posts : 170
Re: Check your RH Engine Mount Uprights
That's no good. How many miles did they have on them?
Who was the original supplier of these mounts?
Psychoideas- Posts : 36
Grenade Hybrids
Psychoideas wrote:That's no good. How many miles did they have on them?
The car is track only. Kit installed May of 2007, probably 80+ days on the track.
Like he said . . . "Grenade Hybrids"
marc a- Posts : 170
I'll make you a good deal on a set of my uprights and plates. Everything on mine are 1/4" thick. The base and the side plates.....
