coolant fans
coolant fans
hi i would like to know who is using stock coolant fans from a NA model 944 ? if so are you using Stock porsche relays or 2 new relays ? if stock porsche wiring how did you set it up with the LS pcm ? or can the fans be controled by the sensors on the stock radiator for fan speeds ? or do i splice the LS pcm pins to the porsche wires for the triggers
matt889- Posts : 214
Re: coolant fans
The Porsche radiator has a temp sender on driver side of it. the two wires control the relay for high - low speeds of the fans and they can be pulled back to inside of car and connected to the ls1 computer. The ls1 computer uses its temp sender on cylinder one, that temp from cylinder one determines the speed of the fans and other things. Some people tap the right rear cylinder for the temp gauge on the cluster.
This is the easiest way period.
red/white Porsche goes to blue high speed
yellow/brown Porsche to green low speed
You can change the temp on and off settings with a tuning program
gdopnt- Posts : 127
Re: coolant fans
These Porsche wires are under passenger side of dash or directly at the fan wiring up front of I would wanna tap into them ?
Re: coolant fans
There is a sensor, tempostat IIRC, on the drivers side of the radiator. The two wires from above attach to that. Clip them and pull them back through the harness to solder to the corresponding LS high and low speed wires stated above.
I did this and it works fine. My car has been a daily driver in the Southeast for the last 4 years.
Re: coolant fans
Or just leave it alone. I have the stock thermostat and relays, left all the wiring alone and it works fine with the LS1 engine. My PCM's fan wires are not connected.
