Clutch slave cylinder on older LT1 swap
So...purchased a 944 with an older LT1 swap already completed (around 2004). Having a problem with the clutch. Replaced the 944 clutch master cylinder because it was leaking. Low and behold the slave cylinder is no good either. The problem is I have no idea what slave cylinder to buy. Does anyone know what slave cylinder was used on the old LT1 swaps? Will you share a part number so I can get this car back on the road? Thank you.
I believe I found my answer....1988 Vette
nphd2000- Posts : 26
Re: Clutch slave cylinder on older LT1 swap
I'm in the middle of this hell right now. Takes a '84-'88 C4 Corvette slave. I bought a new LUK AS-20.
The original GM slaves seem to no longer be available.
Unfortunately I've spent days attempting to bleed the system and cannot.
Rob44- Posts : 38
nphd2000 likes this post
I hear ya
I think I finally got it working. Tried forcing the fluid up from the bottom. I had a ton of tiny bubbles in the fluid. Let it sit overnight and see what happens in the morning!
» Turbo Transaxle wanted
