Clutch Master Options
Wondering what you guys are using as an upgrade to the stock clutch master. Mine is starting to leak and wanted to do the usual bigger bore swap to remedy the typical low pedal using the original. Original plan was to go with the TPC's, but it has been out of stock for a while. Any other viable alternatives that fit?
Leva- Posts : 82
Alternative clutch master cylinder
Hello LEVA,
This seems to be a common problem with the conversion. I started with a new Porsche master but found that the clutch pedal had to be flat on the floor in order to shift.
I purchased a Wilwood 260-10373 master cylinder with a 13/16" bore. It works well but takes more pedal effort.
Remember that you have to slot the holes on the Wilwood part to fit the stock 944 mounting. I also had to make a custom clevis to adapt to the clutch pedal.
Good luck with the swap!
sitcom5406- Posts : 1
