» Magnuson supercharged car?
» WTB: LS powered 968
» Poly engine mounts melted
» Intake choice
» JP's LS1 Conversion
Clutch slave cylinder
Post  GudmundurGeir on Sat Feb 16, 2013 4:03 am
Guys do you know wich type or part number of clutch slave cylinder I can use ? I got one from Greg while ago , had already installed but had to take it a part again. Now it's missing , lost or someone stole it from my garage. Sad But does somebody know part number, I got the first one from Greg Sloan.
GudmundurGeir
Re: Clutch slave cylinder
Post  Arthropraxis on Sat Feb 16, 2013 7:54 am
A C5 slave cylinder works part number 24264180. Or an F-body slave. Make sure to measure to see if you need a shim or not. It is best the one Greg sent is missing. The one he sent me was leaking in less than 200miles, some no name parts store brand. Make sure to get a GM unit it should be AP branded.
Post  Porch on Sat Feb 16, 2013 9:41 am
Supposedly Autozone sells repackaged AP ones, worth a look (just look for "AP" cast somewhere on it...if not, walk away!).
Post  944convert on Sat Feb 16, 2013 1:37 pm
Porch wrote:Supposedly Autozone sells repackaged AP ones, worth a look (just look for "AP" cast somewhere on it...if not, walk away!).
in Iceland? What a Face
Post  Porch on Sun Feb 17, 2013 9:36 am
I think you're on your own there Smile
Post  GudmundurGeir on Sun Feb 17, 2013 7:24 pm
Thanks ! just ordered a new one.
GudmundurGeir
Post  GudmundurGeir on Sun Feb 17, 2013 7:25 pm
yes
GudmundurGeir
Post  Porvette951 on Sat Jan 31, 2015 12:07 am
I have an opportunity to grab a slave cylinder from an f body. I'm using the GTO LS1 with twin disc exedy clutch, think the stock f body slave cylinder will displace enough fluid to engage the clutch fully and do it without any grinding? Best if those using a similar setup could speak up. Let's get some opinions on that slave with the spec 2 and 3 since those are a bit more common.
Porvette951
