1986 5.3 conversion for sale
+3
Hotrodz of Dallas
ryan08
Patb
7 posters
1986 Porsche 944 guard red
Ls swapped with low mile 2007 5.3
Second owner low mile.
Texas performance swap kit with long tube ceramic coated headers, motor mounts and torque tube adapter, oil pan.
5.3 has fresh 243 heads shaved .020 new trick flow springs and seals.
Comp 54-426-11 cam,
rocker trunnion kit,
lingenfelter 58x-24x crank sensor converter,
ls6 intake with pots ported throttle body.
Upgraded and matched fuel injectors.
High flow fuel pump
All new water pump, custom power steering pump for brake booster, ac compressor and associated brackets.
New front suspension to include bushings, bearings and ball joints. Turbo drilled rotors and brembo powder coated brake calipers.
Custom rebuildable front struts.
BMW hydraulic boosted brakes with remote reservoir.
Strut tower support.
Rear coil over suspension with torsion bar delete.
18" Turbo twist wheels powder coated satin black,
upgraded wheel studs with steel nuts.
Turbo lsd trans axle with na 5th gear.
Body has front bumper recessed with holes filled from bumper pads.
Texas performance rear Fiberglass bumper and side skirts.
968 mirrors and door handles. Turbo rear diffuser
968 rear wing.
Rebuilt torque tube with 1 additional bearing installed.
Custom radiator,
new Porsche cooling reservoir.
914 headlight motor conversion.
Larger sway bars.
Power steering,
power windows,
ac and sun roof.
Kenwood stereo with sub and amp.
Turbo cluster.
Located in Fort Lauderdale
$15,000.00 or best.
Comp 54-426-11 cam,
High flow fuel pump
968 rear wing.
Custom radiator,
Larger sway bars.
Power steering,
power windows,
ac and sun roof.
Turbo cluster.
$15,000.00 or best.
Patb- Posts : 46
Markeric likes this post
Re: 1986 5.3 conversion for sale
Hi Pat
Did you do the conversion? Where are the pictures?
Thanks....Ryan
Thanks....Ryan
ryan08- Posts : 15
I did the conversion with a friend, I’ll get better ones this weekend.[You must be registered and logged in to see this image.]
Patb- Posts : 46
What is the red thing right inside the front bumper? Almost looks like a turbo blow off valve
Good eye
I put a turbo on it. I didn’t like it. It’s over powered as is.
I have that whole set up if you know someone who wants a rear turbo setup.
Patb- Posts : 46
PM’d you. Please get in touch.
Yoshjgg- Posts : 6
Hey there, I am new to the forum and am very interested in learning more about your 944 for sale. Please let me know if it is still for sale, I am very interested. Thank you
Arsenauto- Posts : 1
» 1986 Porsche 944 Conversion Near completion for sale
» 1986 944 ls swapped for sale!! MUST GO!!
» any 944s with a v8 swap for sale
