944 LS Conversion Parts near Charlotte, NC
I'm buried in projects and sadly need to move on from my 944 LS swap. Prefer to sell as a package and pickup only. May part out and start shipping after a while if it doesn't sell as a package. Full list is below.
$4,250 for all, which is $1,400 under new prices, not including shipping. All parts are brand new, although I did bolt a few things on for mockup and there is light surface rust on some bare steel parts from storage.
'89 S2 roller with Turbo trans and tons of parts is available as well.
TPC torque tube to bellhousing adapter
TPC pilot bearing adapter with FAG pilot bearing
TPC VSS kit with sensor
TPC engine uprights/mounts with solid bushing upgrade
TPC 1/2" crossmember spacer kit
TPC heater control valve and Gates hose kit (also includes a bypass hose if you want to bypass the heater altogether)
New C5 Corvette 2-piece bellhousing (NLA)
Fidanza aluminum flywheel (C5, 168 tooth)
ARP flywheel bolts
Spec Stage I clutch kit
Spec 23-spline conversion disk + alignment tool
Moroso 20142 baffled oil pan, pickup tube, windage tray, and gasket
Kooks 1-7/8" long-tube headers with gaskets and hardware
Luk clutch slave cylinder (2002 Firebird)
30" stainless braided clutch line and master cylinder NPT adapter
API LS oil filter (not pictured)
ARP flywheel bolts
z1 zonly- Posts : 8
Very Interested
I don't have enough posts to PM, could you send me a message?
krazykarlinthekorner- Posts : 4
Re: 944 LS Conversion Parts near Charlotte, NC
Probably the same situation for me. Shoot me an email
z1 zonly- Posts : 8
z1 zonly- Posts : 8
Very Interested
Resent, didn't get a message that it didn't go, double checked.
Very Interested
Do you have pics of the S2 roller, and other items?
All sold, except 86 Turbo engine.
z1 zonly- Posts : 8
rrracing1970 likes this post
lOOKING FOR A USED IN GOOD CONDITION FOR A 951 TURBO ENGINE WITH NO MAJOR PROBLEMEMS 8599-653-8477 BEFORE 5 pm
call 859-653-8477(Ron)
rrracing1970- Posts : 10
» FS V8 Conversion Parts
» Garage sale. Some conversion parts, various 944 parts
» WTB: LS conversion parts
Today at 12:39 pm by Nath1142
