bellhousing pressure plate interference
Hi all,
I'm putting together another LS 944, and using a C5 Auto bell housing, and 1/4" spacer, between the engine and Bellhousing. I bought an early 2000's 5.7L LS1 Camaro flywheel, and pressure plate. The problem is the pressure plate hits the inside of the bellhousing, even with the 1/4 spacer. Since this has worked for others, I'm assuming I have the wrong pressure plate. What have people been using with success??
Gord.
Gord.
murrayg- Posts : 105
Re: bellhousing pressure plate interference
murrayg wrote:Hi all,
Gord.
Hey Gord,
I went a similar route to you. I purchased a c5 bellhousing and a 1/4" spacer from ICT Billet. I used SPEC Clutches clutch + pressure plate combo. I had the same issue as you with clearance, it was only interferring on the outermost edge of the pressure plate. I bolted the bellhousing to the engine and slowly spun it by hand to see where the interference was, then took a grinder with a flap wheel to the bellhousing. It was a very small amount of material that needed to be removed.
rjarvis- Posts : 61
I am in the process of do an LS1 swap. I had the same thing happen with a SPEC PP. When I installed the bell housing the motor would not turn over, I mean couldn't even budge it. I swapped in an "identical" PP and did not have a clearance problem with the second SPEC PP. It must just be a manufacturing tolerance issue. There just ain't much space in these bell housings.
9turbo51- Posts : 12
i am having the same issue with my spec clutch in the bellhousing I use 2.5mm washers to space it out and it spins now but I need a better answer
mistert1996- Posts : 10
If you are using the 11" clutch, it will hit. The 10.5" clears fine. This only seems to be an issue with Spec clutches in how they built their pressure plate.
» Issues with bellhousing/pressure plate
» Bellhousing Contacting Pressure Plate! (Solved)
» Help with pressure plate (SPEC pressure plate doesnt fit!!)
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
