» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Issues with bellhousing/pressure plate
Post  shwinny on Mon Dec 05, 2011 6:46 am
I just installed my clutch/pressure plate/bell housing and throw out bearing and it seams the pressure plate it hitting the bellhousing. I have a one piece auto c5 bellhousing and i think a 10.5in clutch and pressure plate. Not sure why its hitting but i need to figure it out. I installed the motor and went to manual trun it over and the pressure plate is rubbing keeping it from fully turning over. I will drop the motor next weekend and see why its hitting. I was hoping maybe one of you guys could help. Maybe i have to go to a manual bellhousing not sure whats the cheepest fix.
shwinny
Re: Issues with bellhousing/pressure plate
Post  spence on Mon Dec 05, 2011 7:04 am
From what I read 10 1/2" flywheel, pressure plate and clutch should fit in the auto bellhousing. What flywheel, pressure plate and clutch are you using? Maybe it's 11"?
Post  spence on Mon Dec 05, 2011 7:07 am
Actually I think I have an auto bellhousing too... My flywheel / pressure plate is 10.5"
Post  shwinny on Mon Dec 05, 2011 7:15 am
They are 10.5. I bought the ram clutch and pressure plate. Not sure why.
shwinny
Post  shwinny on Tue Jan 03, 2012 7:53 am
I found out what parts i ordered. I have a
pressure plate
10.5in ram clutches 401 pressureplate Part# 798-401 Competition Pressure Plates
Standard GM diaphragm
10-1/2'' Diameter
3000 lbs Static Pressure
flywheel
1986-92 SB-Chevy Flywheel Fits 305 (5.0L) and 350"(5.7L) 1-piece rear main seal block and crank
Utilizes a 10.4" clutch
External balance
153-tooth, 12-3/4" diameter ring gear
16 lb. total weight
Clutch
Hays 490-40104 Street/Strip Disc
10.5'' Diameter
1-23 Spline
Did i do somthing wrong? Please help.
shwinny
Post  stuart f. wright on Tue Jan 03, 2012 5:49 pm
you say clutches is it a twin disc.i know from experience that the 11 in wont fit. i dont know about the twin disc setup like your using but with a 10.5 single disc is a tight fit itself and i use a 2 piece bell housing
stuart f. wright
Post  shwinny on Tue Jan 03, 2012 6:44 pm
It's a single clutch. I just hope i don't have to buy a diffrent PRessure plate
shwinny
Post  stuart f. wright on Tue Jan 03, 2012 7:04 pm
xshop or admin mite have an idea youl just have to pull it apart and do some measuring i put an 11in presure plate by mistake and cracked my bellhousing and had to weld it so be carful with 2 piece you have better access to see whats hitting i was thinking the 1 piece was a little smaller than 2 piece.mite try pm to xshop or admin they are both very knowledgable about it from part numbers you listed presure plate shows to be a 10.5 .thats ussaly whats gonna hit bellhousing if any thing going to hit
stuart f. wright
Post  bluehellfire666 on Fri Jan 06, 2012 2:58 pm
The first time I installed the clutch setup on the engine and tried to bolt the engine up to the bellhousing I had the same problem...the pressure plate was hitting the bellhousing. I pulled everything back apart, and checked the depth of my flywheel, which was a resurfaced unit I had bought. I compared it to the unit that came with the used RH kit I bought...turns out the resurfaced unit I bought was almost an inch thicker than the one that came with the RH kit. That was my problem.
Hope this helps!
Ethan
bluehellfire666
