dry sump oil system
dry sump oil system
has anyone installed a ls7/9 dry sump oil system into a 944 turbo? would like to use a 6.2 or 7.0 engine if its possible
9sec- Posts : 14
Re: dry sump oil system
I know of one. The Turkey. It’s a black 944 with a green roll bar. This the YouTube video of the build. He goes into detail about his dry sump system.
If that doesn’t take you there search YT for 944 LS. Swap the turkey. Good luck.
LalaLady944- Posts : 8
LalaLady944 wrote:I know of one. The Turkey. It’s a black 944 with a green roll bar. This the YouTube video of the build. He goes into detail about his dry sump system.
I found that video this morning and thanks! I was thinking more along the lines of a ls7 or ls9 setup like I had in my zr1. no gear drive to fail on those setups
9sec- Posts : 14
Yesterday at 8:32 am by Rob44
