» Dual MC Mounting Bracket
Yesterday at 8:11 pm by 87944turbo
Yesterday at 7:50 pm by hp18racer
Yesterday at 5:20 pm by dougr944
» Need help! Car won’t start
Yesterday at 3:51 pm by jess2suityou
Yesterday at 9:44 am by keetle
» Brand new ls3 build
Yesterday at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Yesterday at 1:35 am by Porsche951toLS3
January 2019
78910111213
14151617181920
21222324252627
28293031
Dry Sump Oil Pan Fitment
Post  jpkinerk on Sat May 05, 2018 7:46 pm
I currently have a Champ pan from TPC I'm planning on installing on my L92 swap, but I came across this Champ dry sump pan that says it's only 2" deep. I'll be running a 3 quart accusump, but this would be the best setup if I could make it work. The only reason I abandoned it was at the PRI show I couldn't find a dry sump supplier with a pan that was even remotely close to fitting. Has anyone tried this?
jpkinerk
Re: Dry Sump Oil Pan Fitment
Post  Jchard944 on Tue May 08, 2018 7:11 am
Very interested in this if it works.
Jchard944
Post  jpkinerk on Tue May 08, 2018 8:41 pm
This weekend I'll be measuring the front of the TPC pan and do a general comparison of dimensions.
jpkinerk
Accusump
Post  Jchard944 on Wed May 09, 2018 8:45 am
I am sure you have seen this picture before. I can't find out what he has done for oil pan all it says is "Custom Oil Pan" specifically but it appears he is running an accusump oil pump for the car. Not sure if its possible to reach to him to get more info but its been done.
Jchard944
Post  sharkey on Wed May 09, 2018 1:29 pm
an accusump is not the same as a dry sump. a dry sump has a multi stage oil pump that removes all the oil from the oil pan and puts it into a seperate tank, where the pressure section of the pump pick up the oil and feeds the engine. an accusump is an add on accumulator for a typical wet sump oiling system, it works by holding oil in the accumulator and when the engine oil pressure drop it pushes oil into the oil galleys to ensure there is no loss in oil to the bearings.
the guy that owns that car shouldnt be too hard to reach though, he owns spec clutches.
