» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
Clutch Master
Clutch Master
Post  kevin924kevin on Thu Jan 25, 2018 3:51 pm
Question, why do we not run the vette master? It would make sense that it would work flawless. Thoughts.
Re: Clutch Master
Post  sharkey on Thu Jan 25, 2018 5:34 pm
the corvette master cylinder doesnt mount with a flange and bolts, its inserted into the firewall and turned 1/4 turn to lock it in place. its a real stupid design, my cobalt ss/sc uses the same setup and after a number of years with a performance clutch it cracked and broke the firewall cause me a huge headache.
Re: Clutch Master
Post  kevin924kevin on Thu Jan 25, 2018 7:13 pm
this unit is for a 2005 to 2008 vette. It is a bolt in unit . I saw the plastic one. That could be plated both sides and used. It is a small unit. If the bolt in one fits size wise. Takes the guess work out and in theory is should work perfect being that it came from factory. Just saying.
Re: Clutch Master
Post  sharkey on Thu Jan 25, 2018 7:24 pm
i cant find that one listed anywhere for a corvette. to me that doesnt even look like a gm master cylinder, it looks more like something on an import. all the corvette ones 97+ look like this
Re: Clutch Master
Post  kevin924kevin on Thu Jan 25, 2018 7:34 pm
12568371 GM number I have it saved in my eBay account
Re: Clutch Master
Post  kevin924kevin on Thu Jan 25, 2018 7:39 pm
According to GM will work for 2005 to 2013 it also says it works on 95 plus models.
Re: Clutch Master
Post  Admin on Thu Jan 25, 2018 8:28 pm
Hey Guy,
We have a full size 7/8 clutch master that is modified and fits in the stock location.
Has new clevis that fits stock location.
Has SS hose and fittings for Throw out bearing and clutch master
Comes with  90 degree hose fitting to work with stock 944 brake master.
Steel sleeved.
$134.99 with hose for throw out bearing.
Re: Clutch Master
Post  sharkey on Thu Jan 25, 2018 9:36 pm
kevin924kevin wrote:12568371 GM number I have it saved in my eBay account
all i know is the master you posted a pic of is not what a corvette master cylinder looks like.
corvette master cylinders are the same bore size as what we have already, so its 2 other things that cause the low pedal people complain about: either its less pedal travel or a numerically higher pedal ratio, or both. either results in less fluid than required to actuate the slave far enough. changing the pedal ratio would require angling the master cylinder to prevent it from loading the side of the bore. the simplest way to fix it is to go with a larger bore master cylinder, 13/16" or 7/8".
Re: Clutch Master
Post  kevin924kevin on Fri Jan 26, 2018 10:09 am
Not disputing anything but,
Re: Clutch Master
Post  944-LT1 on Fri Jan 26, 2018 12:42 pm
Maybe its one of those "stock photo/actual part may differ from whats shown" things that lazy sellers do all too often these days.
Re: Clutch Master
Post  kevin924kevin on Fri Jan 26, 2018 12:47 pm
That could be, just thought it was interesting.
Re: Clutch Master
Post  sharkey on Fri Jan 26, 2018 1:21 pm
i searched ebay for "2005 corvette clutch master cylinder" and i saw that image on one auction, in amongst a sea of pics of the one i posted.
Re: Clutch Master
Post  kevin924kevin on Fri Jan 26, 2018 1:24 pm
Ya i know i saw the same thing. I just thought it was and interesting find so to speak.
Re: Clutch Master
