Starter issues
Starter issues
Hey guys. I had to switch out my crank sensor and doing so I had to remove my starter. When I pulled it, I arced the starter body to the power wire. It was quick so I didn’t think I did any damage. Fast forward, I got it all back together and now I have no power when I switch the key on. I get nothing. My question is two parted. Can you look at my wires to make sure I wired it right, and if I did, what did I screw up so I can fix my no power issue. [You must be registered and logged in to see this image.]
zeusrotty- Posts : 444
Re: Starter issues
it depends on how the car is wired, however for a start, the terminal with the wire going into the starter motor should not have any other wires on it. on your starter, that should be the top terminal in the pic. all other wires should be on the other terminal, presumably these are the 12v + cable from the battery, the 12v + feed to the fuse box, and potentially your charge wire from the alternator.
Re: Starter issues
Yep! You are correct. Last night I was thinking about it and I remembered how much of a pain in the ass it was last time I connected the starter, and realized all the wires should be on that post, and the wire from the starter just gets bolted down alone.
