Starter Heat Soak EmptyYesterday at 2:55 pm by Porsche951toLS3
» Intake Piping For Very Tight Clearances?
Starter Heat Soak EmptyYesterday at 2:46 pm by MotoRider42HC
» WTB: LS Swapped 944
Starter Heat Soak EmptyYesterday at 1:16 pm by porschekid7
» tips on removing headers?
Starter Heat Soak EmptySun Jun 23, 2019 8:57 pm by Worryless
» Lighten clutch pedal feel?
Starter Heat Soak EmptySun Jun 23, 2019 8:44 pm by Worryless
» Torque Tube Heat - What is Normal?
Starter Heat Soak EmptyWed Jun 19, 2019 12:14 pm by superman22x
» FOR SALE: Kokeln Dual Master Bracket
Starter Heat Soak EmptyWed Jun 19, 2019 12:13 pm by MotoRider42HC
» Replacement Radiator
Starter Heat Soak EmptyWed Jun 19, 2019 11:20 am by Hotrodz of Dallas
» ISO ls swap done with working AC :)
Starter Heat Soak EmptyWed Jun 19, 2019 8:19 am by stilov
» 1987 Porsche 944 S - Transaxle FOR SALE
Starter Heat Soak EmptyFri Jun 14, 2019 7:04 pm by MotoRider42HC
June 2019
3456789
10111213141516
17181920212223
24252627282930
Starter Heat Soak
Starter Heat Soak Empty Starter Heat Soak
Post  pormgb on Sat May 24, 2014 7:02 pm
I have been battling starter heat soak due to exhaust mods to make my car CA smog legal. When my car was hot, it would take 2 to 3 tries to get the starter to turn over. Some months back I bought one of those $90.00 Ebay mini starters, it was not really mini but larger than the stock unit.
Well, I installed it today with great results. The car now starts within three cranks and starts perfectly when hot. The starter I purchased is adjustable, I was able to move the solenoid as far as possible away from the RH exhaust collector pipe, I also wrapped the starter for additional heat shielding.
pormgb
pormgb
Starter Heat Soak Empty help on furthering my learning
Post  Gutterboy on Tue Jun 03, 2014 10:56 pm
could someone help flip the switch on the light bulb over my head on how heat soak on the start would cause it to require more cranking for the engine to turn over? expansion makes the teeth slip on the flywheel?
i have no idea.
Gutterboy
Starter Heat Soak Empty Re: Starter Heat Soak
Post  Lemming on Wed Jun 04, 2014 7:47 am
Link to starter, I still have this issue and was afraid to buy the low price unit that I was looking at on ebay.
Post  948 on Wed Jun 04, 2014 12:35 pm
pormgb wrote:...When my car was hot, it would take 2 to 3 tries to get the starter to turn over....
Maybe Pormgb will elaborate, but I read this as saying the starter is not engaging the flywheel or turning at all due to heat. This could be caused by a Bendix that is locking up, a seized bushing, hung-up com brush or other electrical issues.
Starter Heat Soak Empty starter
Post  kevin924kevin on Wed Jun 04, 2014 4:33 pm
When starters get to hot they do some what shut down. I had this problem with a big block and headers, as soon as the starter cooled, good to go. Most starters have heat sheild to help prevent this issue. Just my 2cents worth.
Post  pormgb on Wed Jun 04, 2014 5:36 pm
Sure,
The starter engages but turns very slowly (solenoid working, starter engaging with flywheel), the more times I turn the key to the start position, the faster the starter turns. So first time very slow and sometimes stops, second time a bit faster but not fast enough for me to feel comfortable about stating, third time fast enough to start.
If I get the car started, then shut it down and try to restart the motor, the same thing happens again.
When the starter is turning slowly, it feels like its draining all available amps from the battery or the battery is low (could be that too much heat causes excessive current draw). If you look at many LS threads, you get pointed to battery/grounding issues but I know its heat related.
pormgb
pormgb
