Starter issues
Starter issues
Starter works just fine when cold. However, if I come off track, shut the car off and try to restart, nothing. Let it sit for 15 minutes and it starts right up. Anyone else with this problem?
I'm guessing that the heat from my header/y-pipe is the issue. I've read where other conversions suffer from this and one solution is the Ford remote solenoid. See [You must be registered and logged in to see this link.]
However, if you look at the bottom of the website at the right-hand figure, this is essentially the same way that I have my car currently setup. This suggests to me that adding a remote solenoid will not fix my problem. Thoughts?
Re: Starter issues
I had the same problem on an old Ford V8, 351 Cleavland in a Torino. It turned out to be the ground strap from the starter to the frame. It was a little lose and when hot would not make electrical contact. Maybe check all of your grounds are tight. Good luck.
Re: Starter issues
Rich L. wrote:I had the same problem on an old Ford V8, 351 Cleavland in a Torino. It turned out to be the ground strap from the starter to the frame. It was a little lose and when hot would not make electrical contact. Maybe check all of your grounds are tight. Good luck.
Funny, I just went through and did all that before seeing your comment.
Re: Starter issues
Just an update, the issue was not the starter but instead the alternator that was going bad.
