Hydro boost leak and trouble bleeding???
I’m on my 3rd hydro boost replacement(yeah) and second power steering pump replaced. I’m getting a chattering/pulsing brake pedal coming from my hydro boost. I have vacuum bled it(both from the reservoir and the low pressure port). I’m getting bubbles still from the low pressure return port from the distribution plate/block. I’ve got a uv leak kit coming but still. Has anyone else had problems getting their hydro boost bled and leak free? This is well past ridiculous and annoying. Any help would be appreciated. This is the ford hydroboost(‘04 Mach 1) and Porsche MC.
Mike
Mike
Coloberg- Posts : 11
Re: Hydro boost leak and trouble bleeding???
I have an odd feel to the pedal but no other real issues after ~4 years of track duty.
I have the same setup as you describe and used the Turn One power steering pump.
I just kept the front wheels of the ground on initial start and let it self bleed with the cap removed from the power steering pump until the fluid was clear.
Don't think that helps but maybe furthers the conversation...
-Mike
-Mike
hickmaster2001- Posts : 57
You don't say what hydroboost you have. I have a BMW hydroboost with an 80's Chevy Citation pump with the pressure dropped slightly. I haven't had any issues with it in 5 years.
v8carreragts- Posts : 332
» Turbo Transaxle wanted
