A/C Question - WOT Switch?
I'm working through getting the A/C working in my car. I use a Gen IV controller (E67) which I believe uses CAN for the A/C system, so wiring through the GM system is not an option. It seems most LS based compressors, OEM and aftermarket, are not designed for high RPMs. Is anyone running an RPM or WOT switch to shut off the A/C under high engine speed operation, and if so, what are you using?
superman22x- Posts : 272
