Rover V8 bellhousing
Rover to Porsche 944 bellhousing, hydraulic center release bearing, comes with the master cylinder and adaptor plate. I welded a plate to the original bellhousing with 6 datum points to ensure it was centered, then milled the rear face flat. Perfect fit, uses the standard starter motor, removes all the head scratching trying to re engineer another.
$350 CAD for the bellhousing/hydraulic release bearing and the master cylinder. Located in Cambridge Ontario.
x.l.r.8- Posts : 22
