Noisy VSS and stalling???
Hi all,
Early 944 / LS1 with TPC VSS kit. Car ran fine for 2 years...actually...car ran AWESOME for 2 years, now it has developed a stall when coming to a stop. Suspected a VSS issue and sure enough, heres what it looks like when plotted:
Any ideas why it's so noisy? What should the gap be from the sensor to the toothed wheel? Would this cause a drivability issue? Any comments?
Gord.
Gord.
murrayg- Posts : 105
Re: Noisy VSS and stalling???
I set them at .040" clearance. Have you looked at the sensor and wheel? I've seen them get very dirty since they are close to the road in the 944. It's easy to get them covered in grease and dirt. I've had one that got hit by something and bent one of the teeth on the wheel. It made all kinds of weird driving issues.
i found that my signal is clear if i twist the wires like real VSS/ABS wires and the gap i always used a 25cent...
matt889- Posts : 214
that looks like a c5 c6 corvette vss to me
A follow up....problem resolved. I replaced the VSS and now VS on monitor is clean, AND, the car drives MUCH better. Lessons learned - Run a good VSS or not one at all (not recommended), but don't run one that is noisy! It caused all kinds of crazy drive-ability problems. The sensor included with the TPC kit is a popular GM sensor - part number 917-644 (NAPA 600-6224).
