Lights suggestion?
944Hybrids: 924/944/968 and 928 V8 Conversions :: Technical Stuff (other than motors) :: Interior upgrades
Lights suggestion?
Hey, I am looking to upgrade my lights and I'm doubting of what is the best choice. Someone suggested me using HID lights is better than the others. He gave me this site [You must be registered and logged in to see this link.] for me to buy. Has someone have other suggestions which you think is better?
mildracer- Posts : 5
Re: Lights suggestion?
Go to Rennbay.com and order the E code headlight lenses. This allows you to use an H4 bulb. Then order H4 hi/lo LED bulbs. This makes a great headlight setup. Very bright and clear white light.
I quit using HID now that the LED bulbs are so good. No extra wiring to deal with. Simple install.
Which LED bulbs are you using, and any fitment issues inside the popup bucket?
GarethW- Posts : 26
I usually buy these. They have a shorter base and fit well behind the housing.
