Hey Everyone! Been awhile. 1983 944/948 1994 LT1 here
It's been a long time. My 948 is still kicking but I blew a head gasket from a blown water pump... I'm seriously considering letting it go. I starts fine and runs but, I just don't want to deal with a head gasket and I'm getting too old for a car so damn awesome and fast.
This a youtube video of it from 2006:
I welded my own 3" stainless exhaust from two 2.5" stainless header down-pipes. Has a nice big stainless truck catalytic converter on it as well. Has a straight through glass-packed exhaust (stainless as well). I put in the Cadillac ignition system and sealed the Optispark. It's an '83 with a 1986.5 Turbo limited slip transaxle with a cooler. It has the '83 N/A 5th gear for good highway cruising. Gears polished and hardened. It's crazy fast. I used the Renegade Hybrids kit. Renegade also reprogrammed the ECU for better power. It's solid. I updated the torsion bars to some higher strength (forgot mm size). I lowered it a little. Used Renegade lower springs for the front. I did so many things. Has new 911 power seats (one in the car, the other on a shelf) Has an Oil cooler, new water pump, power steering cooler (yes, I put power steering in).
I'll be back. Just throwing this out here. Was a great ride but need to use my time for other things now.
RobotMachines- Posts : 165
Re: Hey Everyone! Been awhile. 1983 944/948 1994 LT1 here
It's been garaged since 1999. I live in Connecticut. I've had it since about 1995/6.
Always used synthetic Mobil 1 and WIX oil filters. I also put in a big external Ford truck filter system (stainless wrapped oil lines). When the water pump blew, the engine oil got too thin and the ECU shut the engine down. Called AAA. Was too late for the head gasket though. I didn't know that until after I replaced the water pump. Thus, it works fine, it just eventually blows the coolant out of the system because of a pressure leak out of one of the cylinders into the cooling system. Who knows, may need new heads.
...and it passes emissions in CT every time with flying colors.
The Cadillac ignition system I put in has one coil pack per 2 cylinders on the LT1 versus the LT1's stock single coil.
