83 944 Front Suspension Help
+2
Hotrodz of Dallas
mred2nice
6 posters
Hello Everyone
I would like to replace all of my front suspension. I have new lower arms and bushings. Where can I find struts,spindle, rotor, caliper...etc? Are these sold as an assembly or is best to by pieces and rebuild yourself.
Thanks for the help,
Ed
Ed
mred2nice- Posts : 79
Re: 83 944 Front Suspension Help
mred2nice wrote:Hello Everyone
Ed
Try ebay. You can usually find complete assemblies there. If not then try googling for Porsche salvage yards. There are a few all over the world.
Morning, you can get what you need from ebay. I did the same thing. Updated my 78 924 to 91 S2 complete.
kevin924kevin- Posts : 927
car-part.com
your best friend for finding parts. List almost all the salvage yards in the country and you can sort by distance to get one close to you.
Thank you for all of the suggestions.
Are there any "special" items instead of getting stock replacement parts? I don't plan to race it but if I am replacing everything I mide as well do it now.
Ed
Ed
mred2nice wrote:Thank you for all of the suggestions.
Ed
Use any suspension from 1987 up and you will be good. Turbo or S2 shocks and struts are best for overall handling. The reason I say 87 up, is it allows you to use late model 944 and 911 wheels without having to use big spacers. Plus brake rotors are a lot easier to change on the front.
Hotrodz of Dallas wrote:mred2nice wrote:Thank you for all of the suggestions.
Ed
Hello:
would I be able to use my current stock wheels?
Ed
no the offset is drasticly different between 83-86 cars and 87+ cars.
If you want to use your stock wheels, then get 85.5 - 86 suspension. And use 86 turbo shocks and struts.
I have the 83' Front Spindles and Hubs if you'd like to buy them. I upgraded to the 87' fronts but am using an adapter to maintain the early struts, so those aren't for sale. I would recommend getting new rotors and wheel bearings, RockAuto has stoptechs for cheap, along with the WB.
Also keep in mind that the early cars used a cable speedo into the DS Spindle, so if you get newer spindles, you will need an adapter of some sort.
Let me know and I will grab some pictures later if you're interested.
944_GASM- Posts : 68
