How to wire the VSS into the GM PCM
+2
Hotrodz of Dallas
Jasonscottw
6 posters
So I have TPC's VSS kit installed, but I'm perplexed as to how to wire it into the PCM- which pin/port, and if there is a plug that I need to wire into those pins to mate up with the plug on the kit- thanks
Jasonscottw- Posts : 125
Re: How to wire the VSS into the GM PCM
Jasonscottw wrote:So I have TPC's VSS kit installed, but I'm perplexed as to how to wire it into the PCM- which pin/port, and if there is a plug that I need to wire into those pins to mate up with the plug on the kit- thanks
What ecu and engine wire harness do you have? I can look and see what wires you need to attach to.
Dear Jasonscottw,
Here is the Pinout for the VSS.
99 Camaro 5.7 Engine
Function-----Pin-----Circuit No. PCM Termination
VSS LO-------A------822------------C2-20
VSS HI-------B-------821-----------C2-21
99 Corvette 5.7 Engine
VSS LO-------A------401------------C2-20
VSS HI-------B-------400-----------C2-21
99 GMC Sierra 1500 5.3 Engine
Punisher948- Posts : 39
Thank you!
Hotrodz, that would be awesome if you could confirm that info:
The computer:
Serv. No. 12586243
Hdw. No. 12583659
In researching the computer numbers I gather it may be from a later year express van, or a CTS??
Originally I thought it was from a 99 truck, but . . .
I hired a guy to do the final wiring cuz I had to go overseas for a bit- he didn't work out (at all) so now I'm trying to sort out his work, and also my work from a couple years ago
And, any idea which wire coming off the VSS is high/lo?
Really appreciate the help-
The computer:
Serv. No. 12586243
Hdw. No. 12583659
http://www.lt1swap.com/2004gto_pcm_pinouts.htm
That pinout might help you figure things out...
"2004: Serv. No. 12586243 with Hwd. No. 12583659 - Mostly GTO and Express vans got this PCM, as well as Caddy CTS-V. MIGHT be in trucks"
Thanks! Looks like I have a mismatched PCM/HARNESS . . .
Question:
The VSS harness/plug has two wires, but I have three options on the PCM:
-VSS low (pin 20)
-VSS hi (pin 21)
and
-VSS output (pin 50)
What do I do? And yes, I advanced searched this forum and the big 3 LS forums, and the only suggestion I found was to ignore the VSS hi, which doesn't make sense-
Also I'm unsure of what the VSS output would even do/function?
Thanks . . .
Question:
-VSS low (pin 20)
-VSS hi (pin 21)
and
Thanks . . .
never used the kit, but looking at a pic of one it has a yellow and black wire on the sensor. yellow would be high, black would be low. the vss output on the pcm is exactly that, a vehicle speed sensor output signal, it could be used to run an electronic speedo in some applications.
The VSS output goes to the dash of the Camaro/Vette. The hi/lo go to the sensor but I don't know if polarity on the sensor matters.
Thanks all- now I just gotta re-pin 20 and 21.
For some reason the PCM is devoid of inputs at those locations-
