Mon Jul 08, 2013 1:56 pm by Admin
LS1 Timing Cover
LS1 Timing Cover
For you guys that rebuilt your LS, did you use the GM front timing cover alignment tool or were you able to install the cover by placing the oil pan on first? That tool is seemingly hard to find and expensive from what I've heard. I haven't been able to hunt down a place that rents it either. Thoughts?
jpkinerk- Posts : 174
Re: LS1 Timing Cover
I did not use the tool. While my motor was out I put the cover on loose, fit the seal in what I thought was relaxed snugged up the cover and tapped it in. Dry as a bone going on two years.
gdopnt- Posts : 127
i normally put the pan, timing cover and balancer on all at the same time. get the timing cover on with the bolts loose, get the balancer pulled on, then put the pan on, get all the bolts started, tighten the pan up first (dont forget to align the back of the pan to the block) then get the timing cover tightened down. never had leaks.
I didn't use it, just a straight edge. The gaskets are pretty forgiving; not like the BS Porsche oil pan gasket lol
Techno Duck- Posts : 447
Thanks guys, that makes sense and is a big help. Appreciate it!
Today at 5:08 am by gwistrup
Yesterday at 8:12 am by Nath1142
Mon Apr 22, 2024 5:22 pm by lowform
Mon Apr 22, 2024 5:12 pm by lowform
Mon Apr 15, 2024 5:28 pm by JW1970
Mon Apr 15, 2024 4:59 pm by JW1970
Mon Apr 15, 2024 7:51 am by Raymond-P
Fri Apr 12, 2024 1:07 pm by Rob44
Wed Apr 10, 2024 8:09 pm by LS982
Mon Apr 08, 2024 11:54 pm by lowform
