Lt1 Motor mounts
Lt1 Motor mounts
Hi everyone. New to the forum. Years ago I purchased a conversion kit for RH. I have not been very pleased with the overall fit and finish of the kit but that is another topic. My motor sits a bit too close to the passenger side. Ive got about a 1/8" gap on the passenger side with about a 3/4"+ gap on drivers side. Also the motor appears to sit a bit too low for my liking. Very close to cross member and steering rack. I have try to pry, lift, shift , loosen, tighten every way and it always settles in the same spot everytime. Was thinking about trying a new set of mounts from someone else. Any recommendations on another company that sells LT1 mounts? Thanks.
whty8911- Posts : 33
Re: Lt1 Motor mounts
After I pulled the original 2.5L engine I measured the drive shaft tip from the passenger side member and the drivers side member and the found the same offset as you did...dunno why.whty8911 wrote: I've got about a 1/8" gap on the passenger side with about a 3/4"+ gap on drivers side.
944convert- Posts : 253
The more I thought about it the motor favors the passenger I believe. With the intake, turbo, exhaust, etc taking up mostly of the drivers side. With that being said Im thinking about just seeing how it goes and if it causes a problem.
Message Eric(admin) he can make you mounts if hes up for it. Never hurts to ask. I bought my mounts from him and they fit fine so far. I havent finalized my motor install yet as im doing a slightly different build then commonly used here. Tuned port 350 fully rebuilt with bigger cam and fuel adjustments.
Remy6908- Posts : 35
lt1 engine mounts
Can anyone know if the TPC offers even mount to the engine LT?.
Pavka944- Posts : 17
lt1 engine mounts
I would like to buy .To TPC poor contact .You definitely have a lot oforders in the new year.
