Yesterday at 9:03 am by chrenan
Fri May 25, 2018 8:34 pm by superman22x
» WTB: 944 Turbo Roller
Thu May 24, 2018 8:32 pm by knight76
Thu May 24, 2018 7:52 pm by matt889
» New here needing help
Thu May 24, 2018 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Wed May 23, 2018 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
May 2018
78910111213
14151617181920
21222324252627
28293031
Lt1 Motor mounts
Lt1 Motor mounts
Post  whty8911 on Wed Dec 25, 2013 9:47 am
Hi everyone. New to the forum. Years ago I purchased a conversion kit for RH. I have not been very pleased with the overall fit and finish of the kit but that is another topic. My motor sits a bit too close to the passenger side. Ive got about a 1/8" gap on the passenger side with about a 3/4"+ gap on drivers side. Also the motor appears to sit a bit too low for my liking. Very close to cross member and steering rack. I have try to pry, lift, shift , loosen, tighten every way and it always settles in the same spot everytime. Was thinking about trying a new set of mounts from someone else. Any recommendations on another company that sells LT1 mounts? Thanks.
whty8911
Re: Lt1 Motor mounts
Post  944convert on Thu Dec 26, 2013 4:59 pm
whty8911 wrote: I've got about a 1/8" gap on the passenger side with about a 3/4"+ gap on drivers side.
After I pulled the original 2.5L engine I measured the drive shaft tip from the passenger side member and the drivers side member and the found the same offset as you did...dunno why.
Post  whty8911 on Thu Dec 26, 2013 5:06 pm
The more I thought about it the motor favors the passenger I believe. With the intake, turbo, exhaust, etc taking up mostly of the drivers side. With that being said Im thinking about just seeing how it goes and if it causes a problem.
whty8911
Post  Remy6908 on Sun Dec 29, 2013 8:19 pm
Message Eric(admin) he can make you mounts if hes up for it. Never hurts to ask. I bought my mounts from him and they fit fine so far. I havent finalized my motor install yet as im doing a slightly different build then commonly used here. Tuned port 350 fully rebuilt with bigger cam and fuel adjustments.
Remy6908
lt1 engine mounts
Post  Pavka944 on Fri Jan 01, 2016 5:15 am
Can anyone know if the TPC offers even mount to the engine LT?.
Pavka944
Post  Admin on Fri Jan 01, 2016 5:24 pm
Yes, I have a couple sets left
lt1 engine mounts
Post  Pavka944 on Tue Jan 05, 2016 3:06 pm
I would like to buy .To TPC poor contact Crying or Very sad .You definitely have a lot oforders in the new year.
Pavka944
