Help Me Buy Correct Donor Car for L36/67 RWD Project
Page 1 of 1 • Share •
As some of you know I have a build thread started on a Porsche 944 that I'm trying to equip with an L36/67. I live in California where the engine swap rules are complex. My eventual goal is to have an L67 in the Porsche but first I need to rig it with an L36 from a Camaro/Firebird because I need a whole bunch of other parts off the donor car in order to pass California engine swap inspection. The donor car (V6 Camaro/Firebird) will donate: motor, ECU, 5spd trans, bell housing, clutch, pedal assembly, exhaust from headers to cats, fuel tank, fuel filler pipe and cap, evap cannister and all the engine accessories such as steering pump, A/C compressor, alt.
I'd be grateful if you guys would chime in and make sure that I understand this correctly - it is my belief that if I buy a '96/7/8 V6 Camaro or Firebird with a 5 spd manual transmission that the bell housing/clutch/flywheel will mate up to an L67 supercharged motor with just a few mods to convert the L67 flex plate over to the L36 style flywheel.
Thanks for any feedback.
sparkydog- Posts : 86
Re: Help Me Buy Correct Donor Car for L36/67 RWD Project
i know for sure that the rwd bellhousing will bolt to the fwd block, both are the small gm pattern. the flywheel should bolt up, i see no issues there, however ive never done it. im limited on my 3.8l knowledge. i used to do a bunch of 60 degree v6 stuff back in the day.
sharkey- Posts : 575
I hope you get yours going soon. I'm in the middle of a similar build with an L67. I think I have all the parts now so hoping to get it back on the road one of these days. Headers are holding me up a bit.
Sirayden- Posts : 30
Wow, you have impressive skills from what I've seen so far!
My setup will be using an L67 but with a turbo (or maybe twin turbo or twincharged). I'll be running the stock transaxle, bellhousing from a late 80s Camaro 2.8L with twin starter pockets, new slave cylinder for a 2002 corvette and a custom stage 3 clutch and pressure plate built by Clutchnet. The car drove fine with the Grand National engine it had before but upgrading it to the L67 since they're cheap and can handle big hp on stock components. I'm in Vegas if you think you might be heading out here someday.
Thanks for the kind words! Las Vegas would make a nice shake down cruise for the car whenever I get it running.
This guy is selling some clutch parts. Might be worth a look...
» Correct way to repair pitch marks
» For all my grammatically correct friends.
» Correct harness set up
» Championship Predictions Winner/Relegation
» Best Piriformis Stretches
» LSA Supercharged 86 Porsche 944
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» 924 Twin Turbo 5.3 C5 T56 swap!!
» Lighten clutch pedal feel?
