Wilwood 13/16" vs Stock?
I've been doing a little reading, and have seen that people run both master cylinders it seems for the V8 conversion? I have an OEM C5Z slave cylinder I am planning to use. What are the most recent thoughts on the Wilwood 13/16" clutch master cyl vs stock?
If the Wilwood is the optimal choice, how easy is mounting it? Use the stock studs, and modify the master slightly? Along with a custom clevis to attach to the pedal?
Thanks!
Thanks!
superman22x- Posts : 272
Re: Wilwood 13/16" vs Stock?
superman22x wrote:I've been doing a little reading, and have seen that people run both master cylinders it seems for the V8 conversion? I have an OEM C5Z slave cylinder I am planning to use. What are the most recent thoughts on the Wilwood 13/16" clutch master cyl vs stock?
Thanks!
I use the 13/16 wilwood. Most important thing is to get the angle correct so that the plunger goes straight in, otherwise they start leaking fairly quickly!
The 13/16 is ideal and you only need a file or dremel to mod it. It will also seat properly to the firewall angle when bolted down.
It needs a 90° npt adapter.
Ok, great. If I just mount it to the Porsche studs, it should be aligned perfectly then. As far as the clevis, do you make a custom one or modify the Porsche one?
I have made many, but don't any more as I posted the adapters dimensions here.
I do have a couple spare npt adapters and 30" SS line if you're interested. $30 shipped us-48
I think I've got some jic adapters and lines around here somewhere.
I haven't found the drawing for that clevis. Is it posted in this sub forum?
It's here somewhere. I think in clutch MC upgrade thread.
You would be looking for this
gdopnt- Posts : 127
Ah, awesome, thanks!
One more quick question, how do you go about connecting to the corvette slave cyl? Is there a quick connect adapter to -3AN?
Awesome, thanks! You guys are quite efficient at this.
