steering shaft clocking question
I posted this in the LS1 conversion section but thought it may be better here.....
I have seen mention of maintaining the clocking of the steering shaft while adding the length for the spacers, on the car I bought the PO had started to lengthen the shaft but started out by cutting it. I have no way to tell where it should be clocked from one end to the other, does anyone have info on this subject that they could share ? With a splined shaft does it really matter, the only thing I think it would get you is access to the bolts with out having to turn the wheels, is there more to it ? It is a 1986 turbo if that matters......
Thanks for any help,
Jim
I have found one reference to the second joint being at about 70 degrees off of the other one but that was by eye with no real number to verify....
Jim
hutchjc1- Posts : 68
Re: steering shaft clocking question
That is what I am looking for !!!!
Thank you for the help.
Jim
Jim
It's 10 Degrees, not 15... I built a lot of these Borgeson replacements at 10 also...
Thank you for the help !
Jim
Jim
