Clutch slave cylinder
Guys do you know wich type or part number of clutch slave cylinder I can use ? I got one from Greg while ago , had already installed but had to take it a part again. Now it's missing , lost or someone stole it from my garage. But does somebody know part number, I got the first one from Greg Sloan.
GudmundurGeir- Posts : 45
Re: Clutch slave cylinder
A C5 slave cylinder works part number 24264180. Or an F-body slave. Make sure to measure to see if you need a shim or not. It is best the one Greg sent is missing. The one he sent me was leaking in less than 200miles, some no name parts store brand. Make sure to get a GM unit it should be AP branded.
Supposedly Autozone sells repackaged AP ones, worth a look (just look for "AP" cast somewhere on it...if not, walk away!).
Porch wrote:Supposedly Autozone sells repackaged AP ones, worth a look (just look for "AP" cast somewhere on it...if not, walk away!).
in Iceland?
944convert- Posts : 253
I think you're on your own there
Thanks ! just ordered a new one.
944convert wrote:Porch wrote:Supposedly Autozone sells repackaged AP ones, worth a look (just look for "AP" cast somewhere on it...if not, walk away!).
in Iceland?
yes
I have an opportunity to grab a slave cylinder from an f body. I'm using the GTO LS1 with twin disc exedy clutch, think the stock f body slave cylinder will displace enough fluid to engage the clutch fully and do it without any grinding? Best if those using a similar setup could speak up. Let's get some opinions on that slave with the spec 2 and 3 since those are a bit more common.
Porvette951- Posts : 15
