Help Identify this Torque Tube
I got a cut down torque tube through a junkyard to mock up my bellhousing on my 4g63 swap. I got this in the mail....it was supposed to be for a early 85 944 NA.
The splines are too long and the pilot bearing surface is too long as well?
Any ideas what this came from?
SOB Racing- Posts : 22
Re: Help Identify this Torque Tube
Looks like it's an automatic (has recess for circlip used to keep rubber damper quiet) ...should be able to use it with a 5 speed but not vice versa (can't easily use 5 speed torque tube with an automatic).
Also looks like the drive shaft has been pulled forward a few inches...weird.
944convert- Posts : 253
Yeah...I had him cut the torque tube to 24" just so I could used it for mock up. I asked to to include 2 of the support bearings so I think he just hammered everything forward.
I Im'd the junkyard guy and he said it came out of a manual car and he didn't even think of looking at the c-clip groove till I pointed it out. He said he would cut another and send it if i needed it. the pilot bushing is pretty worn out so I will probably have him ship another so i can get the engagement right
SOB Racing wrote:He said he would cut another and send it if i needed it.
Up to you....I doubt it's needed
I have the Torque tube and shaft dimensions posted here somewhere. The spline engagement is critical as well as pilot input.
xschop wrote:I have the Torque tube and shaft dimensions posted here somewhere. The spline engagement is critical as well as pilot input.
Yep I have those dims...mainly I wanted to know where this came from so I could talk to the junk yard guy in case he gave me a hard time.
That's why I bought this mock up tue is to double check the pilot bearing engagment.
Today at 12:39 pm by Nath1142
