LT throttle cable
LT throttle cable
I have looked all over the forum and can't find anything specific but I need to know how to connect the factory lt cable to the 944 pedal assembly. Any and all info would be great.
Remy6908- Posts : 35
Re: LT throttle cable
Using the lokar cable.
If you have the 36" the simple end shaped like a "c" with the pin - that will fit into the pedal mount with the rubber piece (the rubber piece stays in). I cut off the opposite end and ran the cable threw the fire wall don't forget to put a nut and washer on the cable before you fish it threw the fire wall. Cut the outer sleeve to fit ( from fire wall the throttle body mount). The cable is adjustable. I purchased a brass barrel ran the cable threw it and the ran two Allen headed blind screws into the barrel. I bought the assorted barrel pack and used a bigger barrel so had to drill the throttle lever for it to fit.
gdopnt- Posts : 127
Im using the factory LT cable not the lokar. The pedal end just has a plastic barrel piece that im not sure how to connects
I am using GM #12550676 a barrel connector that is swaged, like a butt connection.
You could go about this in several ways.
- Swage a butt connection
- Silver solder a butt connection
- Overlap cables and pass them through a barrel connector with a screw to hold them.
Things to remember.
- Leave a suitable amount of cable when cutting the end of the 944 cable, that attaches to the pedal....shown as rubber "ring" on this image taken from a Rennlist post by 951Porschiste
- Be careful to make sure the connector doesn't bind on anything during pedal movement
- Be sure to check that you have 100% throttle
- Be sure that the pedal touches the floor stop, so that you aren't putting excess tension on the cable when at full throttle.
Silver solder butt connection
Things to remember.
Last edited by 948 on Thu Oct 16, 2014 2:06 pm; edited 1 time in total (Reason for editing : Adding detail)
Can you give me a little better descrip. on what you did. If you have a picture that would be great. This is one of the last things in my install and im very eager to finish.
Revised post, added some more detail. Sorry I don't have any pictures of what it did.
Today at 8:08 am by gwistrup
Yesterday at 11:12 am by Nath1142
Mon Apr 22, 2024 8:22 pm by lowform
Mon Apr 22, 2024 8:12 pm by lowform
Tue Apr 09, 2024 2:54 am by lowform
