Frosty's 83 944 LM7 Project
+5
frostyballs
wingdog
majormojo
99sierra4x4
9 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Frosty's 83 944 LM7 Project
I may be missing something but man I don't think the master cylinder is gonna be very happy without the 12 degree angle.
944-LT1 wrote:I may be missing something but man I don't think the master cylinder is gonna be very happy without the 12 degree angle.
Could you please explain... I'm all ears if I can learn something.
frostyballs- Posts : 25
No problem. The stock master cylinder was bolted to what we call the cereal bowl which is just a mount that bolted to the firewall and gave the master cylinder a 12 degree angle with respect to the firewall. This allowed the brake pedal pushrod to push in-line with the master cylinder piston. Without the angle, the pushrod would enter the master cylinder at such an angle as to cause the piston to score the piston wall thus damaging the cylinder.
Heres a picture of the stock "Cereal Bowl" with a plate from RH bolted to it.
Heres a wedge I had made to bolt to the plate that replaced the cereal bowl.
Heres the setup out of the car to measure the stock angle.
Heres somebodys angled wedge in place.
Transmission
The transmission is on and the spare tire well is mostly removed. I have yet to address the brake MS, but I will get to it.
Sombody's wedges
Somebody's wedges...........mine.
Don't forget to reinforce the firewall!
simon123- Posts : 125
Why did you put a spacer on the waterpump? U plan on using a truck crank pulley?
matt889- Posts : 214
Just a heads up, i spent much effort trying to retain the truck accessory spacing and it looks like you plan on doing the same (spacers on the water pump, not changing the crank pulley, etc). If you get a thicker than stock radiator, like one of the many 3" versions that will fit, you're going to have difficulty fitting a fan(s) that will provide any significant air flow.
I ended up changing the accessory spacing to the f-body spacing. Buys you ~3/4" inch and is definitely the easiest way around the problem.
FrostedFlakeJake- Posts : 263
Page 2 of 2 • 1, 2
Page 2 of 2
