944 Auto X Wisconsin
Finally got it out and did some Auto Cross.
Running -3 Camber up front, 0 toe and -2 Camber out back with 1/8" toe in. Also running 600lb springs front, and 700 rears with TB delete, and stock sway bars.
Waiting for a friend to bring his scales and weigh the car, still have a lot of adjusting and seat time to go.
99sierra4x4- Posts : 121
Re: 944 Auto X Wisconsin
Curious to see what your weights are. At last year's Pro Solo, my car tipped the scales at 2314. Glad to see you're out there autocrossing. Are you running with coilovers in the front??
skywalker01- Posts : 477
A bunch of the folks from my club (MAC) were at the match tour this year. Are you local or did you drive in? I'm heading to Eau Claire this weekend for the Chippewa Valley club's first event.
haroldk- Posts : 140
Skywalker - I am running front coil overs, I believe they are 600lb springs.
I am local to the milwaukee region, I am in the process of purchasing a car trailer so I can start going to more events that are farther away (since i have a nice diesel truck to do my towing).
I think my next local event is on the 5th, excited to get back out there and get some seat time.
Are they the koni coilovers from Paragon Products? Are you running 10 or 12" springs??
I am running Ground Control all around, I would have to measure how long they are, I am not sure off the top of my head.
Okay, so you're running an 85.5-up 944......
Its an 84' chassis, with 89 Turbo Rear Arms, early front arms with balljoint extensions, late turbo spindles up front, also all the turbo body panels, ect.
So yes most of the car is 85.5+
