F/S LS Conversion parts
+2
Elliseast
kjducati
6 posters
Griffin Aluminum Pro Series Radiators 1-26221-X $150.00
Granatelli Motor Sports Mass Airflow Sensors 350119-C $250.00
Hamburger's Performance Billet Aluminum Ignition Coil Brackets 1100 $125.00
Sanderson Headers LS158-P $250.00
Tilton 75-Series Universal Master Cylinder Kits 75-875U $60.00
Wilwood Combination Remote Tandem Master Cylinders 260-7563 $100.00
TPC LS Engine Conversion Installation Basic Kit $1,200.00
New C5 Corvette Bell Housing 2 piece $200.00
VSS Kit with Sensor $110.00
Painless LS1 Wiring harness $550.00
LS1 Engine $2200.00
----SPECS----
Factory Aluminum LS6 Block
Weiseco -25cc pistons, 3.905" bore
K1 6.125" rods w/ ARP 2000 rod bolts
Factory LS1 Crank
317 heads w fresh valve job and Comp 918s good for .620" lift (roughly 8.5cr with current heads)
Mild 224 Comp cam
Comp timing chain set
LS7 Lifters
LS6 intake manifold w F-body TB
Front timing cover, rear cover, and valve covers
ARP Head Study & Main Studs
Alternator, Water pump, and power steering pump included as well.
New Harmonic Balance done by Perry automotive in mishawaka
1985 Porsche 944, nothing under the hood. $2000.00
50/50 shipping is terms for sales.
Shipping from zip code 46552
Few other things I will post when I gather them together, if you have any questions feel free to shoot me a message.
LS1 Engine $2200.00
----SPECS----
Factory LS1 Crank
Mild 224 Comp cam
LS7 Lifters
kjducati- Posts : 18
Re: F/S LS Conversion parts
I'd like all things minus the engine. Feel free to PM with quote shipped to Freeport, Maine 04032.
Thx.
Elliseast- Posts : 3
Got your PM...can't reply back as of yet (not enough posts). PM your number, and I'd be happy to give a call to hammer out the details. Cheers.
If Ellis dosen't take all parts i'd be interested in radiator, headers, VSS, bell housing, and TPS kit.
I realize this is my first post, but I have paypal funds ready to send.
I'm just starting my adventure in what is going to be my last 944 build.
This will be #4 I've built, but first swap.
thanks
Phil
thanks
Phil
phlip- Posts : 67
Also interested in everything except the car itself... If the others fall through or you have some stuff left please PM me with your email/phone. Thanks!
Aaroneous- Posts : 3
This is what I still have to sell
Still got some parts im selling, Here are the pictures of the actual items.
Painless LS1 Wiring harness P/N#60508 $675.00
BOSCH Fuel Injectors 0280155890 240cc 22.5lb $200.00 for all 8 (USED)
Professional Products Powerflow Fuel Rails 10612 $125.00
Taylor 409 Series High Performance Race Wire (Plug Cables) $40.00
I'll take the fuel rails and injectors. Still can't PM yet.
Send paypal info to [You must be registered and logged in to see this link.]
thanks
Phil
thanks
Phil
phlip- Posts : 67
update
Fuel rails and injectors are sold.
Would you be interested in splitting up your TPC LS Engine Conversion Installation Basic Kit? I need mounts and BH adapter.
thefallen- Posts : 3
If the motor is still available, I would be interested. I am 3 hours away, and could pick it up.
Sterling Doc- Posts : 113
» RH Conversion Parts
» Garage sale. Some conversion parts, various 944 parts
» Conversion Parts LT/LS
