Conversion Parts LT/LS
Misc Conversion parts for sale! All prices OBO so just make offers if you want! Prices include shipping except the hubs/spindles. PM me or mpk944 @ sbcglobal dot net or paypal mpk944 @ gmail dot com
Cereal bowl with brake master adapter plate from RH –Includes the pushrod supplied by RH and the master cylinder with new reservoir and cap…. 100 Sold
Custom made brake master adapter plate machined at 10 degrees which was determined the correct angle from the firewall. I had two made where one is installed in my car with a wildwood MC and works great. This has no pre-drilled mounting holes so that the user can install whatever MC they want…. 50 Sold
2008 Corvette LS3 waterpump. Has 2K miles on it and comes with elbow and tstat…. 100
LS low mount alternator bracket (1998-2002 Fbody). Never used… 50 sold
Late style 944 gauge cluster modified by RH via Hollywood Speedo for LT engine. Has an actual check-engine light as seen above the fuel level gauge. Ribbon board on back needs repair or just take tach and check light out and put in yours ….80
LS pilot bearing adapter. Made by XSchop. Never used…. 50
Tickperformance LS slave cylinder shims/spacers 0.113” and 0.180” never used ….20
Porsche 968 engine vanity cover. Not sure why I have this but I guess theyre pretty hard to find. Has one broken tab but doesn't affect it. Just covers the firewall area to make the bay look clean I guess ...160
Also have a set of 1987 hubs and spindles w/dust shields …. 150
Re: Conversion Parts LT/LS
Bump! Nobody?
Paypal works. mpk944 at gmail dot com
Free!
PM'd you.
Master cylinder and adapter parts still for sale?
Hey,
Do you still have these? Hit a snag in my conversion and can't progress with out them!
Thanks, Dave
Thanks, Dave
Elegant Toad- Posts : 8
The cereal bowl/plate, pushrod, MC and reservoir (first picture) is still available. The aluminum adapter is sold.
PayPal sent!
Payment sent for the cereal bowl, adapter plate, rod, and master cylinder. Name, address and phone # supplied with payment. Let me know if you need any other info.
Thanks, Dave
Thanks, Dave
Parts recieved in great shape!
Thanks for the prompt shipping, everything arrived safely. I'm excited to get them installed.
Dave
Dave
