944 wolf bumper mod issues
Look I have the bumper off and pads removed. About to start doing some sanding and hole filling.
But..... I drilled a 3/16 hole in each bumper shock and neither will move. Any ideas? A 3lb hammer and it wouldn't budge. Help!!!any ideas???
Cmcbay- Posts : 14
Re: 944 wolf bumper mod issues
What i did was remove the shocks from the car, used a jack to collapse it ubder the bumper og my truck, then tack welded the housing. I am assuming youre trying to tuck an NA bumper?
w00tPaPa- Posts : 14
Indeed you are correct. May have to try that
Cmcbay- Posts : 14
Then i would just compress it with something heavy, truck with a jack, in a press or a vise. And just add 4 tack welds around the shock. Should be go to go!
I'll try the jack and truck when I get home. Don't have a press....yet
Cmcbay- Posts : 14
