Turbo Bumper Conversion
has anyone heard of or considered this front bumper conversion?
if so what are your thoughts and impression of the product. my car is a 85 (late), and i am considering this product. i have searched and it seems that Porsche was very proud of the driving lights (AKA Fog lights) for that reason i was considering turning the driving light into a brake cooling duct.
Punisher948- Posts : 39
Re: Turbo Bumper Conversion
The look is better then the original big metal bumper in my opinion but it's not as straight forward as the site you linked says. Unless it's already made to fit the na fenders and header panel. You will either need to modify your fenders or replace with turbo fenders as well as replace the header panel between the headlights and headlight lids with the turbo to make it fit properly.
Check this out.....http://www.944online.com/cgi-bin/forum/forum.cgi?board=944body;action=display;num=1294680012
Remy6908- Posts : 35
Punisher948 wrote:has anyone heard of or considered this front bumper conversion?
To add to Remy6908 comments.
I would stay away from those turbo look bumper covers, most are made from fiberglass and require allot of trimming for a good fit. I once had one on my 944 and I hated it, I eventually sold it and went with a proper turbo bumper cover (found a red one with lights).
If you don’t want to go with turbo fenders, you can trim your N/A fenders to match the turbo bumper cover. If you go this route, you will need the turbo bumper support, bumper shocks, header panel, headlight covers and modify your N/A lights wiring harness.
I would look around for a complete bumper cover, you may find one that matches your paint (I did), trim you fenders and you are done (not that hard, use a cut off wheel).
I went that route with my car; you really can’t tell I don’t have turbo fenders.
pormgb- Posts : 186
That kit listed above does say "conversion" so it may be specifically made to adapt the NA 944 to a turbo look bumper without changing the fenders etc. I've been looking at this kit from AIR. Seems like it has a reputation for a good fit. It's not exactly the same as a true turbo/S2 conversion, but much easier. It might be that one above is reselling the AIR bumper.
majormojo- Posts : 82
majormojo wrote:That kit listed above does say "conversion" so it may be specifically made to adapt the NA 944 to a turbo look bumper without changing the fenders etc. I've been looking at this kit from AIR. Seems like it has a reputation for a good fit. It's not exactly the same as a true turbo/S2 conversion, but much easier. It might be that one above is reselling the AIR bumper.
Yes, mine was a conversion cover but I still needed to buy a turbo bumper support with shocks and lights, those bumper covers are made to fit the NAs nose panel and headlight covers. The challenge with these bumper covers is where they meet the rounded section of NA fenders, this has to be perfect fit otherwise you see a gap.
Here is a picture of mine, it took a great deal of work to get it to fit. You can see the gap between the nose panel, I was not able to close that gap.
pormgb- Posts : 186
» WTB: Turbo 951 Front Bumper Cover
» Turbo front bumper for sale w/ lights.
» 1/3 Life Crisis... 1987 944 turbo ls1 conversion
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
