Turbo radiator fan sensor
So I'm using a turbo radiator in my swap and picked up a used fan sensor to plug the hole below the upper radiator inlet. It looked like it would screw right in, but it appears to be too small and the hole, upon further inspection, doesn't appear to have threads in it. My friend brought over another fan sensor to be sure I didn't have the wrong part, but we had the same issue as with the first sensor.
Anyone have any ideas? Thanks in advance.
jpkinerk- Posts : 174
Re: Turbo radiator fan sensor
I am using my 951 radiator and the sensor should definitely thread in. Did you get your radiator from a reliable source. By the way, the factory sensor and wiring works fine for controlling the fans.
Geoff Daniels- Posts : 29
