Today at 6:33 am by Patb
Yesterday at 6:35 pm by haroldk
» ecotec swap
Sat Mar 17, 2018 3:53 pm by Hotrodz of Dallas
» New 944 widebody & aero
» Wilwood MC on it's side
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
March 2018
Turbo radiator fan sensor
Post  jpkinerk on Wed Feb 12, 2014 9:15 pm
So I'm using a turbo radiator in my swap and picked up a used fan sensor to plug the hole below the upper radiator inlet. It looked like it would screw right in, but it appears to be too small and the hole, upon further inspection, doesn't appear to have threads in it. My friend brought over another fan sensor to be sure I didn't have the wrong part, but we had the same issue as with the first sensor.
Anyone have any ideas? Thanks in advance.
Re: Turbo radiator fan sensor
Post  Geoff Daniels on Thu Feb 13, 2014 12:02 pm
I am using my 951 radiator and the sensor should definitely thread in. Did you get your radiator from a reliable source. By the way, the factory sensor and wiring works fine for controlling the fans.
Geoff Daniels
