brake line union
brake line union
Sorry I have looked with out any luck, I am trying to find any info on the coupler needed to extend the brake lines when adding the hydro and Porsche m/c. Anyone know what the threads on the lines are or better yet a part number if you have done this. Are all of the lines going into the master the same thread ? Are they bubble or flares ?
Thanks again for any help !
hutchjc1- Posts : 68
Re: brake line union
Bubble flare, 10mm, that's what I bought.
http://www.ebay.com/itm/291681755099?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
hickmaster2001- Posts : 57
Thank you that is what I was looking for, are both lines the same ?
Jim
Jim
Pretty certain the entire car has the same fittings for the brake lines. I can't be completely sure as I haven't verified though. Hope that helps
Yes it does help, thank you for your time !
As mentioned, bubble flare 10mm. Your local auto parts store should have the couplings and sections of pre-made lines.
https://944hybrids.forumotion.com/t2774p75-ford-hydroboost-to-porsche-951-master-cylinder-adapter#31414
