New lt v8 swap
New lt v8 swap
I am new to the site and have been reading some forums trying to get and idea of what I wanted to do with my 951. After tearing the engine down and finding all that needed repaired It have decided to do a swap. I consider myself a good mechanic and fabricator and I have done engine swaps before but none with EFI. I have found some good information on this site and hope to get more helpful information here. I have found a 95 corvette motor with only 67xxx miles, and got everything from exhaust to computer. I was wanting information about the wiring harness at this time. I am going to pull all the wires from the loom and figure out what I need, and if I am missing anything. If anyone has a diagram or such it would be helpful. Thanks
jonb944- Posts : 8
Re: New lt v8 swap
Welcome to the board. What year 944 are you putting the Vette engine in? Wait, never preposition last. Of what year Porsche 944 do you wish to install a Vette engine?
Early year 944s are a little different but I can't really help with it.
RobotMachines- Posts : 165
Re: New lt v8 swap
It's a 86. I am still getting all the parts together. I have been looking for a good flywheel since the motor I purchased had an automatic. I still have to get the pressure plate and bellhousing and slave cylinder. I think the oil pan may need to be changed also, or at leasted modified.
jonb944- Posts : 8
Re: New lt v8 swap
I have a couple of questions, does the brake master cylinder booster have to be removed to or can it be replace with smaller one? I have a t-5 bell housing for my swap, is there a diagram for an adapter?
jonb944- Posts : 8
Re: New lt v8 swap
Yes you'll need to remove the brake booster.
Not sure there is a diagram for the T5 bell housing. You'll have to design you own adapter for that. There is a diagram for the C5 corvette bell housing.
Re: New lt v8 swap
How much does that affect the braking? Does the master cylinder need to be changed or will it work as is?
jonb944- Posts : 8
hydroboost
I dont have my hydro boost changed over yet but i drive a 2007 comany van and didnt know it had hydroboost until i looked and there it was. It works well and I couldnt tell the difference between the types and it is easy to push. Non power brakes would not be fun to drive. google "2000 ford mustang hydroboost" and it will show you the power unit and the master I paid 100 for the whole thing at the auto yard. Read in the brake mods section and you can see things also check the gallery and look over other members engine compartments.
gdopnt- Posts : 127
ready to fit motor
I have everything together to start fitting the engine in the car and I was reading some of the posts and was wondering if there was any problem with running solid mounts. I know there will be some vibration.
jonb944- Posts : 8
