majormojo's LY6 swap
+14
matt889
gdopnt
wingdog
Tehone
DJ.
Gutterboy
majormojo
18 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: majormojo's LY6 swap
Thanks. I just got my rad back from being modified to remove the top mounted rad cap neck. I will do a test fit shortly and see where my height is at.
majormojo- Posts : 82
Looking good......... why is there no thumbs up emoticon...
kizzlecake- Posts : 6
Temp sensor recommendation?
Hey, I made some progress after a few months of procrastination... Flywheel, PP and clutch are installed, I started on a bracket to support the rad and finished up mounting the brake/clutch reservoirs and make new hard brake lines. See latest pics in the album link in my sig.
Question about the temp sensor install now. Back when I started, the recommendation was for VDO 323421 and an adapter. I see now from [You must be registered and logged in to see this link.] that there is now a sensor available that works with the OE 944 dash gauge and doesn't need an adapter. Maybe that's a better option now? I already have the 323421 sender though.
So if I proceed with plan A, what adapter do I need to fit the LS block (I assume I can pull the plug in one of the heads opposite where the PCM temp sensor is)?
Or should I scrap that idea and just use the new option? Main reason to not go with Plan A is that I'm worried the adapter will pull the sensor out of the coolant flow enough to give inaccurate readings. Any thoughts on that?
Getting a 404 error when I click the link to your album.
chrenan- Posts : 203
Weird. I updated with a new sharing link.
Page 4 of 4
