Value of 944 Complete Turbo Engine?
I have pulled the turbo engine from my 1986 944. I am sellling the complete setup. Includes EVERYTHING. And I do mean everything, Oil cooler, radiator, expansion tank, exhaust, intercooler, AC compresor, PS pump, KLR / DME, etc, etc.
I looked on ebay for comps. I dont think the ones on there are as complete as mine.
Actual mileage on mine? Unsure. Odometer read 151k when I got it 9/2009 but was not working. Car has passed CA smog test twice now. the last time was 18 months ago and has been sitting since. I have never driven this except to get it working to pass emmissions (once to register it and once for its bi-annual). The first time I took it in, it was a mess. One of the injectors was missing a pintel. So I rebuilt the injectors at Witchhunter. Replaced the MAF. Installed a Lindsey crossover delete. Replace the dried out vacuum lines. installed new fuel regulators, just about everything you can think of. It runs clean and the turbo seems fine. I still have the smog test results.
What do you guys think I should ask for this?
Re: Value of 944 Complete Turbo Engine?
Poke around on Pelican, rennlist, ebay etc. and see what folks are asking.
I've seen the $1500 figure in a few places, but not sure if they are actually getting it.
Good luck.
Good luck.
Vbjunker- Posts : 1
You should be able to get at least 1900.00+ with all of that. It's basically a complete conversion for someone who has an NA motor. That amount is what I got for mine, and it wasn't as complete as yours.
zeusrotty- Posts : 444
