PS Pump outlet
PS Pump outlet
I am using a Turn One PS Pump, what outlet fitting bore size are you all using on this pump?
My steering is very heavy/notchy at low engine rpm but seems ok at higher rpm when the car is moving.
Re: PS Pump outlet
I used a standard -6 AN fitting and hose, I haven't driven much, just around the neighborhood, but up to 45 MPH it felt great, that's as fast as I could go on the side street.
Re: PS Pump outlet
This is what i got,
-6AN to 16mm x 1.5 o-ring . (RUS-648060)
Techno Duck- Posts : 447
