coolant hoses
coolant hoses
95 LT1 350 into 89 944 turbo. What hoses do you use to connect the radiator to the engine? I have the RH custom radiator.
Thanx
Q
Thanx
Q
Re: coolant hoses
Hi
Thanks for quick reply. They did send some instructions to cover the whole installation but nothing specific about hoses. I did get the kit in 2004 though.
I thought that someone on the forum might have been through the process and would know which hoses fitted best.
I’ll contact them as you suggest.
Thanx
Q
Thanx
Q
Re: coolant hoses
Or do what most of us have done, including those of us with RH kits from way back, measure and head down to the local parts store and find a match.
Hoses
Make some full scale sketches to take to the parts store.
This is also what I did, I have swapped three different cars and find it hard to actually find a perfect hose. I use two pieces per hose and join them with either a filler/bleed plug or a drain cock. Both from Jegs.
The drain cock was useful today as I had to change out my leaking plastic heater valve for a metal one.
Pictures tell the story.
UPPER HOSE WITH BLEED PORT
LOWER HOSE WITH DRAIN COCK
Last edited by fliermike45 on Mon Jul 01, 2013 8:49 pm; edited 1 time in total (Reason for editing : Added Jegs)
