SOLD. Custom Tilton Clutch Master Adapter
$85 shipped cont US, high quality machined aluminum for 944/968 firewall.
Last edited by 968gene on Thu May 16, 2013 9:35 pm; edited 2 times in total (Reason for editing : pictures)
968gene- Posts : 259
Question
Howdy,
This may be a good alternative to what I was planning (but haven't found the time) to make. Do you have any photos of it mounted in the car? Is it designed to replicate the angle of the stock MC? Also, I've not used the Tilton MC, but have been using the Wilwood equivalent. Do you know if those two have the same mounting dimensions by chance? If not, which Tilton model is this designed for?
Thanks!
Dan J.
Thanks!
Dan J.
Dan J- Posts : 117
Re: SOLD. Custom Tilton Clutch Master Adapter
Also will you need to extend the push rod?
944convert- Posts : 253
Push rod needs to be extended, yes.
The back is cut to fit the firewall.
ID is approximately 1.5"
Last edited by 968gene on Sat May 11, 2013 2:55 pm; edited 1 time in total (Reason for editing : size)
