» ecotec swap
Yesterday at 7:02 pm by sharkey
» What is VSS?
Yesterday at 10:53 am by C4924S
» The famous Hydroboost issues....
Yesterday at 10:43 am by Hotrodz of Dallas
» RHD Conversion Issues...
Sun Apr 22, 2018 4:24 pm by UK952
» Considering doing LS1 Swap
Sat Apr 21, 2018 10:29 pm by hooplajr5
» WTB: 944 Turbo Roller
Sat Apr 21, 2018 8:31 am by Maxx
» Blue Alternator Wire
Fri Apr 20, 2018 11:22 pm by Porsche951toLS3
Thu Apr 19, 2018 4:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Thu Apr 19, 2018 6:16 am by bikerdude
Thu Apr 19, 2018 2:33 am by Flashy2003
April 2018
30
SOLD. Custom Tilton Clutch Master Adapter
Post  968gene on Thu May 09, 2013 7:31 pm
$85 shipped cont US, high quality machined aluminum for 944/968 firewall.
[You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]
Last edited by 968gene on Thu May 16, 2013 9:35 pm; edited 2 times in total (Reason for editing : pictures)
968gene
Question
Post  Dan J on Fri May 10, 2013 11:33 am
Howdy,
This may be a good alternative to what I was planning (but haven't found the time) to make. Do you have any photos of it mounted in the car? Is it designed to replicate the angle of the stock MC? Also, I've not used the Tilton MC, but have been using the Wilwood equivalent. Do you know if those two have the same mounting dimensions by chance? If not, which Tilton model is this designed for?
Thanks!
Dan J.
Dan J
Re: SOLD. Custom Tilton Clutch Master Adapter
Post  944convert on Fri May 10, 2013 12:10 pm
Also will you need to extend the push rod?
Post  968gene on Fri May 10, 2013 9:44 pm
Push rod needs to be extended, yes.
The back is cut to fit the firewall.
ID is approximately 1.5"
Last edited by 968gene on Sat May 11, 2013 2:55 pm; edited 1 time in total (Reason for editing : size)
968gene
